69 transmission cross member
Old Jan 7, 2015 | 09:03 PM
Craig Ferguson's Avatar
Default 69 transmission cross member
I have am removing the transmission from my 69 Camaro and thought the trans cross member was removable but once the bolts were removed it will move forward and backward a couple of inches but is no way coming out of the car, it is hitting on the floorboards on both sides. Is it supposed to removable? I seem to remember being able to remove the one in my 2nd gen. factory 4 speed car....but that was years ago
Old Jan 8, 2015 | 05:59 AM
flat tire's Avatar
loosen the body mount bolt on one side and hit the cross member with a BFH
Old Jan 9, 2015 | 08:13 AM
Everett#2390's Avatar
I follow Flat Tire's suggestion except I don't loosen subframe.
I use the BFH and knock the member to the rear - now floorboard is custom fit for next time.
Use the above only if a daily driver or #3 Day Camaro - If pristine, then no BFH.
The floorboard dent is under the seat and covered by carpet.
Old Jan 10, 2015 | 09:49 AM
Hey Thanks, A little redesign of the floor pan with the BFH and it came out. The redesign is under the seat anyway.
cajundude
82-92 V6 Tech
Jul 31, 2010 09:49 PM
markbass
82-92 V8 Tech
12
Jun 23, 2009 01:35 AM
REAL69Z11
Nov 22, 2007 08:34 AM
fotoboy
Dec 3, 2005 02:12 AM
