New suspension and car not level
Old Mar 27, 2010 | 08:02 PM
Juggger's Avatar
Default New suspension and car not level
I have a 1969 Camaro that leans to the left. It is between 1/2 and 3/4 inch in the rear and between an 1/8 and a 1/4 in the front. It has varied the several different times I have measured it. I have always measured on level ground. I just recently had all new leaf springs, coil springs, shocks, shackles, bolts and bushings replaced. It raised the whole car up about an inch, but it still leans to he left. I and the mechanic at the place I take it to had it up on the rack today to see what was going on... we could not see anything that would cause it. The coils are seated properly, it does not look as if the frame is bent, or that is has ever been in any sort of accident and all of the other bushings look good. The floor pans and frame or very solid. Oh, and when they put all the new stuff on they tightened it on the ground, so as not to cause the bushings to bind. Can anyone help me out? Is this just something I have to deal with? Will fabricating a shackle that is 1/2" longer and mounting it in the rear help to level it out? Any advice would be greatly appreciated!
Old May 27, 2010 | 04:47 PM
libertyforall1776's Avatar
Might want to post some pics while on a lift...
Old May 27, 2010 | 06:01 PM
Was it level brfore the new springs were installed. Otherwise, it is possible that the new springs are not matched, or one side is for one model and the other side is for another. That is assuming the frame is really straight or not sagging from old age. Also may want to check body/frame mountings, anything is possible in a 40 year old car.
Old May 27, 2010 | 06:12 PM
18436572's Avatar
i was thinking body bushings too.
saw it on a 67 chevelle , all one side had too many spacers over the bushings that other wise looked perfect.
my budy at the garage is a wizard when it comes to finding what part is bent for alignments.
he just starts measuring gaps bettween stuff that is the same side to side.
mostly patience and a comfortable place to work is the best thing
Old Oct 19, 2012 | 06:05 PM
TheTank69's Avatar
So, did you figure it out?
Old Oct 20, 2012 | 09:33 AM
77thor's Avatar
I would also check the body mount bushings. They could be completely rotted out on one side of the car causing the lean.
Old Oct 20, 2012 | 09:39 AM
Guys, you gotta watch the thread dates. This is over 2.5 years old, which is also the last time the OP logged on to our site.
Terry
Dec 31, 2012 07:28 AM
Mustang_Eater
Nov 24, 2010 09:35 PM
gearheadLT1
Sep 4, 2009 08:26 AM
CamaroX69
67-69 V8 Tech
Jun 24, 2008 10:36 PM
my2ndcamaro
Mar 22, 2006 05:58 PM
