How does Shackle length effect Rear Ride Height?
Old Jan 17, 2021 | 10:18 AM
67champ's Avatar
Default How does Shackle length effect Rear Ride Height?
Does anyone know when changing shackle length to adjust rear ride height, is it as simple as changing shackle length say one inch, to move ride height one inch? (ie 2 inches to change 2 inches)... Thoughts?
Thanks!
Old Jan 17, 2021 | 12:00 PM
Everett#2390's Avatar
Yes, it is this simple. Spring arch never changes.
Old Jan 17, 2021 | 03:08 PM
67champ's Avatar
Great, Thanks for that insight!
Old Jan 18, 2021 | 07:45 PM
67champ's Avatar
In the next month or so I will probably get to this. I will post my results.
Old Jan 18, 2021 | 11:03 PM
To answer your question, no it's not that simple. Lowering the rear of the leaf spring one inch by use of a longer shackle will raise the rear body about half that amount, because the axle is at the center of the leaf spring pivot point (spring eye to eye).
If you were to lower both the rear and front leaf spring mounting points an inch, then that would equal an inch of rear body rise.
Old Jan 19, 2021 | 05:41 PM
Zspoiler's Avatar
If you use a longer shackle to raise the back of your car .It will also raise the center of gravity and lose handling as well.
sbrussell0221
Feb 28, 2012 11:42 PM
95camarodude
Mid West
Sep 16, 2011 12:09 PM
skar
Aug 28, 2007 06:36 PM
Don Hog
Jan 27, 2007 11:03 PM
sewerrat
Jul 7, 2006 02:03 AM
