Hi - I need help on suspension for my 67 Camaro
Old Oct 31, 2013 | 03:49 PM
Po' Boy's Avatar
Post Hi - I need help on suspension for my 67 Camaro
Hi All,
Still new to this site.
Hopefully I can gain some good advice from you members.
I have a 1967 RS/SS Camaro.
  • It currently has a 383 Stroker putting out ~ 435HP
  • 350 TH tranny with a 2800 stall converter
  • 12 bolt posi rear end with 3:73 gears.
  • Frame connectors are installed.
I need help/advice in the following areas.
1) I need to know what shocks to install and the ratio's 50/50, 30/70, ?
2) Has anyone used and would recommend either the Comp Engr. Slide -A - Link Traction Bar System or the Cal Tracs Traction Bar System. Possibly someone has done a comparison on these two systems?
Although I do drive this car on the street and to the car shows I want to set it up to hook-up coming off the line, so I need advice on a drag racing shock package, ratio's and vendor and a traction bar set-up.
Thank you for your time and any help you can provide to me!
I'm looking forward to your advice
Po' Boy
shawnathan
Jun 4, 2012 09:56 AM
Cornbreadx
Feb 21, 2012 10:54 PM
mitchecw
Feb 14, 2011 11:11 AM
imalixZ28
Nov 16, 2009 07:40 PM
srich1207
Apr 9, 2008 06:28 AM
