disc brake conversion
Old Aug 30, 2016 | 01:12 PM
guruatbol's Avatar
Default disc brake conversion
I'm probably asking a question that has been asked a thousand times. Please indulge me.
My 67 standard has manual drums. Manual is OK but like my 67 Mustang I would like to change them over to disc.
I have searched and searched and everything I find requires changing the spindles. Don't have to on the other car.
Is there a way to go without changing spindles? What if any issues are there? Can it be done with off the shelf parts from Napa instead of a kit?
Lastly, cost differences?
Thanks for your understanding.
Mel
Old Sep 2, 2016 | 09:39 AM
Zspoiler's Avatar
The spindles are slightly different.No a kit works better unless you want to get the parts off a donor car (1967-9 Camaro,1968-4 Nova) and get the parts that need to be replaced.
Old Sep 3, 2016 | 12:23 AM
guruatbol's Avatar
Thanks.
I know GM cars tend to be more interchangeable than the Mustang Ford world. I guess I was hoping for an easy way out.
Mel
Old Sep 3, 2016 | 08:55 AM
There are el cheapo, keep your drum spindle conversion kits on ebay, such as this one: 14" Wheel GM Disc Brake System Zero Off Set 1967 Camaro 67 F Body | eBay
Personally though, I would do a complete spindle changeover. There are decent name brand spindle kits that start in the $500 range. Swapping spindles isn't difficult, just a little more time consuming. Take into account the condition of your current ball joints too, if they are worn, they'll want to be replaced which means you'll be removing the spindles anyway. I just finished replacing the ball joints on my 69 Vette resto project, not difficult, just takes some time. But then, this stuff isn't new to me. Are you trying to save money, save labor time, fit within a certain skill set, or all the above?
Old Sep 5, 2016 | 07:04 PM
The summit kit looked pretty good.
I am planning to make my own kit to convert my 67 over to the late 4th gen brakes. The late 4th gen have dual piston aluminum calipers and upgraded rotors and pads are dirt cheap.
250motorsportz
May 8, 2008 12:51 PM
libertyforall1776
May 16, 2007 10:00 AM
trevscamaro
Mar 25, 2007 02:47 AM
trevscamaro
