any suggestions for 69 better handling
Old Sep 13, 2007 | 08:59 PM
eas69's Avatar
Default any suggestions for 69 better handling
I have a 69 and would like it to handle better, it is stock and really loose. Help me out Please.
Old Sep 13, 2007 | 10:11 PM
CamaroKid16's Avatar
Default RE: any suggestions for 69 better handling
Well, i would say the same thing. Even tho i have a 4th gen it should be fairly universal. Lower it, struts and shocks, sway bars, panhard bar, sturt bar, polyurethane bushing kit, and some good tires. That would get you to a point that you would be insanely happy with.
Old Sep 14, 2007 | 11:22 AM
riceeater's Avatar
for a 69, lower the front with springs, as well as the leafs in the back. install some aftermarket sway bars, the bushings, some good shocks, like maybe Bilstein, subframe connectors, tires, a-arms could also be replaced, maybe some other things I cant think of, but that sort of stuff. comp engineering and detroit speed, as well as Jegs and summit have these kinds of parts. I would also install some slapper bars in the back to help your launch. Amost forgot, AFTERMARKET BRAKES!!!!!! gotta be able to stop, and Baer or wilwwod have good kits for these cars
Old Sep 14, 2007 | 11:49 AM
eas69's Avatar
All good suggestions. Does anyone offer a matched package, something so that I know it will all work correctly together?
Old Sep 14, 2007 | 09:12 PM
riceeater's Avatar
Competition engineering and Detroit speed both do as I recall
Old Sep 15, 2007 | 09:02 AM
eas69's Avatar
Thanks I will ck them out
Old Sep 26, 2007 | 12:57 AM
1969 SS's Avatar
after you know all your hard parts are good (ball joints, tie-rods, endlinks, etc), you are going to get your best bang for the buck by replacing stock bushings with urethane bushings. think of it as building a solid foundation for future mods.
your car will ride a little rougher but I think you will be happy in the long run and those bushings will give you so much less deflection than rubber
sraey8
Dec 29, 2010 07:36 PM
AmirGTR
Jun 30, 2010 01:31 AM
jjjr311
LS Series Tech
Jan 14, 2010 04:09 AM
FATHOM GREEN 1969
Nov 6, 2008 10:14 PM
gr8cars1
May 9, 2007 01:06 PM
