1969 Camaro newbe
Old Dec 13, 2012 | 11:11 AM
heritage03's Avatar
Default 1969 Camaro newbe
Just bought a 69 and I am findiing that the power steering squeals when I first start the car. If I turn the wheel stop to stop the noise stops, is there a way to correct this issue? Can the box be rebuilt to correct the problem. Belts and pulleys are good!
Thanks
Old Dec 13, 2012 | 01:33 PM
77thor's Avatar
The noise is most likely coming from the belt.
You say the belt is good. Is the belt new??
I would look for grease or oil in one of the pulley grooves,
and if you find any then de-grease both of the pulleys.
Another cause could be mis-aligned pulleys.
Old Jan 13, 2013 | 10:22 AM
FBodyjunkie's Avatar
Could just be a loose belt. Sometimes, its the simplest fix we overlook,lol
Old Jan 13, 2013 | 03:46 PM
Camambro's Avatar
April 2012 ROTM
Power steering fluid could be low
Old Jan 14, 2013 | 06:23 PM
heritage03's Avatar
Both the belt and pump are new with new pulley as well. Fluid is right up and it to only has 1500 miles on it along with the entire driveline of the car. Just wondered if anyone else had the same issue as i feel it is the gear box that is causing the issue. Thanks for the replies guys!
Old Jan 16, 2013 | 04:25 PM
Everett#2390's Avatar
Next time the engine is running and belt is squeaking, spray belt with WD40.
If noise goes away, change belt and/or check belt pulley alignment as suggested.
Of course, only after you check belt tightness.
Old Jan 17, 2013 | 05:46 PM
heritage03's Avatar
Everett, I will try that, thanks!
Red 69
May 22, 2012 09:15 PM
mace
Jan 31, 2011 09:35 PM
DUANER
Jul 20, 2009 11:30 PM
85Irocjerry
Feb 21, 2008 10:52 PM
Ponykiller
Jul 4, 2005 09:37 PM
