Newbie, building a 68 Camaro for my bro-in-law in Iraq
#62
RE: Newbie, building a 68 Camaro for my bro-in-law in Iraq
Comp Performance Group came through huge for us. They hooked us up with a Zex LSX wet nitrous kit and also have hooked Shawn up with discount pricing on any Comp Performance Group part for the rest of his life. They are also going to be putting out a press release about the project and said they'll get us in with a few magazines!
And my little man approves!
Also got the body completely stripped down and the junk subframe off the car. This weekend we'll be POR-15 painting the front subframe and I'll hopefully have the rear frame rails by then as well. I built a little body cart for the front out of some junk 2x4s that were in my way. Worked out pretty well since the back is on casters.
#63
We received a donation from POR-15 of their rust-proofing paint system! We had hoped to get the front subframe stripped and painted this weekend, but I got a wicked cold yesterday and was KO'd most of the day. Only thing I got done yesterday was yanking the spindles to send to Ed Miller for the LS1 conversion..
#64
Well, I felt a little better this afternoon and I got a ton of work done. I had to split my time between the Camaro and a huge powdercoating job for a friend's machine shop, so I wasn't as productive as I could have been, but gotta keep the side business going!
Anyway, I got the firewall modified to fit the LS1 booster and MC. First I took the booster and cut out a template for the hole. Then I traced it off on the firewall and went to town with the cutting tool. Fits like a glove! I still need to weld in the section where the old hole used to be and modify the booster shaft to fit the existing brake pedal, but so far so good!
#65
Looks nice, thanks for all the template, firewall, and completed photo's. Those types of pics make me believe I haven’t gotten in over my head, I have, but at least my ego is telling me I haven't!
#66
OK, finally was able to get some real work done on the car! I got the pedals all fitted for the Modo Innovations covers, then I took everything down to HRT Performance to be tanked and blasted. Tonight I powdercoated it all semi-gloss black and reinstalled the Modo covers. Came out amazing. I also cleaned and painted the parking brake assembly. I ordered all new pedal bushings and pins and all from Firewheel, so those should be in tomorrow or the next day, then I can get the pedals all ready to go back in the car once I finish up the LS1 booster and T56 Master cylinder modifications to the firewall and get the seat supports welded in this weekend.
Before:
During:
After:
Before:
During:
After:
#67
Got the LS1 booster conversion all finished up. I measured and cut the stock brake rod and welded it on to the LS1 booster shaft. The I welded in some metal and cut it to match the hole in the firewall.
#70
Got a lot of goodies in the last few days! Autometer sent us some SWEET new Ultra-Lite II gauges, along with some schwag.
And Second Skin donated a TON of stuff. Damplifier, blankets, sprayer, knife, Spectrum, adhesive, etc. Basically, everything to keep this car quiet inside!
