Newbie, building a 68 Camaro for my bro-in-law in Iraq
Old 10-07-2007, 09:21 PM
4birdman's Avatar
Default RE: Newbie, building a 68 Camaro for my bro-in-law in Iraq
OK, quick update here! I've been busy trying to sell off the extra parts to fund the AirRide setup for the car. AirRide is sponsoring us at a discounted price, so we want to jump all over it. Right now here are some photos of the car in the shop, along with the final rendering from Ben. Note the stripe on the cowl that he came up with and the Wheel Vintiques V40 wheels.
We also received a set of brand new black front and rear seat covers thanks to 78ta.com!
  #52
Old 10-08-2007, 08:03 PM
4birdman's Avatar
Got the front subframe on the AutoTwirler rotisserie tonight. This thing is sweet! I was able to load the subframe and adjust it by myself, I love this tool. :thumbsup:
How many f-bodies can you pot in this picture?
  #53
Old 10-09-2007, 09:16 PM
4birdman's Avatar
Did a little work on the taillights tonight. The bezels were in terrible shape and were rusted and pitted. The pictures make it look a lot better than is actually is, but it still came out pretty good. I'm a perfectionist when it comes to my powdercoat, so I'm going to block same it to take out some of the small runs and bumps and lay a second coat on it to see if it will fill some of the pits. I'm going to go tomorrow to pick up some stainless hardware for the back of it, too. I changed the lenses from the stockers to a set of LEDs that MuscleRodz hooked me up with.
So it went from this:
To this:
Before and after:
  #54
Old 10-14-2007, 07:48 PM
4birdman's Avatar
And then we move on to the car.
We took the rear spolier off and it looks like it was held on by two studs and a ton of silicon. One more thing to fix. The trunk lid looks very savable, though.
Also got the interior most of the way torn down. The wiring is trash and most everything needs to be replaced, but I want to give Shawn a new car, so I would be replacing all of that anyway.
And the rear axle that a friend gave me for the car. It is only a 8.2", but I'll freshen it up and it should do fine. I gotta use what I can if it isn't donated for this build, so 8.2" axle it is.
And then we tore down most of the front sheetmetal and all on the car. Gonna try and finish smoothing the firewall and getting it cleaned up soon.
  #55
Old 10-14-2007, 07:56 PM
Blade's Avatar
June 2007 ROTM
how did the tail lights turn out? how is the surface bc of the rust?
  #56
Old 10-14-2007, 10:03 PM
4birdman's Avatar
I haven't laid the final coat down yet, but you can still see some of the pits and stuff through the PC. I'm going to try a new trick on it with the powdercoat and see if I can fill the pits.
  #57
Old 10-28-2007, 07:15 PM
4birdman's Avatar
Got some new parts! A friend of mine gave me an LS1 intake and coolant tubes for the engine. I also got in the Bullitt replica wheels that Custom Wheels Market gave me a discount on.
Haven't done much to the car since I just bought some new tools since I broke a few and some of mine just plain sucked. Gotta have the right tools to build a good car! The aftermarket frame is being lengthened for me by Staples Engineering, so once that is done I'll be able to get the back of the car back together.
  #58
Old 10-29-2007, 06:35 PM
4birdman's Avatar
The guys over at RotorsOnline.com hooked us up with some Axxis brake pads for the LS1 brake conversion! These guys have been a huge part of making the LS1 brake setup come into place.
  #59
Old 11-07-2007, 08:19 PM
4birdman's Avatar
Well, it's going a little slow right now, but things are going on in the background! No photos worth posting though. The engine is being built, the trans is being rebuilt, and I still haven't gotten the frame back, but should have it back by the weekend.
The spindles are going out this week to be modified to fit the LS1 brake setup, and I have modified the firewall and brackets to fit the LS1 brake booster. Once it is done and cleaned up I will post photos.
So that's where I am at. Prothane just donated a total Motion Control package for the car, so I'll be finishing up the front subframe as soon as the POR-15 that was donated gets here.
So as you see, it is slow now, but will hit me like a sock full of pennies in a week or so!
  #60
Old 11-08-2007, 07:15 PM
4birdman's Avatar
Whoops, I do have more photos for you guys! I thought I had posted it mocked up with the new wheels!
Size:  48.2 KBName:  4-1.jpg
Quick Reply: Newbie, building a 68 Camaro for my bro-in-law in Iraq
