My Project 1968 off eBay
#41
RE: My Project 1968 off eBay
Here it is from the outside all together... I put the glass in there to align the filler panel. It needs to be adjusted... All of these panels in the pics are only mcked up to check for fit and what not... None of them are attached nor will they be until I get my blaster up and running...
[IMG]local://upfiles/11028/D47534F0E6E041DFA7767813A01E06CE.jpg[/IMG]
#43
Here is a pic of the rotted part of the rocker that I cut out, sorry no before pics, I forgot to take them...
Funny, now I have "Rotted Rocker. tweedily tweedily tweedilt tweet" Stuck in my head to the tune of Rockin' Robin.... Ugh... i bet now you do too!!! HA!
[IMG]local://upfiles/11028/D7F566815F02435D809D4D18BFA606F1.jpg[/IMG]
#44
The next thing that I did was remove the pax side subframe connector.... Well, most of it... I smashed my finger, almost broke my sawsall and destroyed a cutting wheel trying to get this thing out... I hate whoever put it in...
[IMG]local://upfiles/11028/84C107B41D5F487CA9EADB0E7E3AD55A.jpg[/IMG]
#45
After I got most of it out... As you can see, I had to remove it to get the subframe off the vehicle...
[IMG]local://upfiles/11028/A2789C6085BE41D7944312169B85C73B.jpg[/IMG]
#46
Here is a view from the pax floor before and after... I'm not sure if you can tell that they wleded the subframeconnector at both the front and rear of the GAPING HOLE they put in the floor...
[IMG]local://upfiles/11028/4AD60D0F9F1E43E0AB9FC483EC9D273D.jpg[/IMG]
[IMG]local://upfiles/11028/9D931A328E63473B8F4A438945600345.jpg[/IMG]
#47
Hey, this is a bit off topic but I started a thread in the off topic section of a couple of videos of my Jeep... Check it out if you are interested...
https://camaroforums.com/m_166729/mp.../tm.htm#166753
#50
hahaha... I am an aircraft mechanic for my real job so I am used to keeping my work area as clean as I can...plus I don't like laying in a pile of **** when working on my side under the car...!
