My 69 project. aka what I have to work with
#102
Next week? only if I had tons of money - I wish. My budget is only a few hundred bucks for now, yeah yeah I know... Once I hit budget its back to just looking at it till I save up again. The only way ill do somehting even close to a rotisserie is if I use a heavy sheet of ply wood, round one edge and bolt it to the font end - do the same on the back and poof, rotisserie.I am going to put more pictures up if I do that.
Anyone know the name of the glue for body panels? Im going to spot weld them in place but I dont know anything about the glue stuff. If its true/real, it sounds much easier than running a bead (which I can not do well) and sanding it down.
#103
3M makes panel adhesive called Automix. I have the special gun, you can pick one up on ebay.
Check 3M's website for more info, they have different adhesives for different purposes.
#104
hack job for the gear selector
Also, I was able to update most of the pictures from this thread. So you can go back and see thm now..
Here is another pic of the heads. Still debating on using them on the 350. Cant afford new heads or I would get the aluminum ones.
#105
glad to see you are working on the Camaro again. good job with the Pics too. Im still in a holding pattern on my heads. word on the street is they could be cracked from the heat (from the fire). Im sure somebody around here has a nice set of heads just layin around they will want to donate to the Scooch. keep up the progress man, we have got to hurry and get these things back on the road while they will still sell us Fossil Fuel to run them!
#106
yes, I know. at this rate I will still be working on this car while Im in a retirement home.I have a set of heads. Cast iron off a 350. You can have em', I dont need em' just have to figure out how to get them there.
