my 69 camaro project
Old Jul 19, 2010 | 09:57 PM
  #321
Squid's Avatar
and yes....I weld in shorts.
Old Jul 20, 2010 | 12:07 AM
  #322
The bracket looks pretty good. You might want to look at welding triangle gussets on both sides though. At the very least, the compressor is likely to tweak left and right.
But, you don't want it to fatigue the weld and make it fail.
Old Jul 20, 2010 | 06:00 AM
  #323
orocker's Avatar
December 2011 ROTM
Santas Little Helper
Yea he thought about that on the one side. Still may do it.
Old Jul 21, 2010 | 04:40 PM
  #324
Squid's Avatar
It has a 3rd bolt to the heads off the back side so that shouldn't be much of an issue. To get the compressor to line up properly, a little tweak in when the belt is tight will probably be a good thing.
Old Jul 24, 2010 | 12:17 PM
  #325
orocker's Avatar
December 2011 ROTM
So onto the AC hoses. Today the squid drilled 3 more holes into the firewall. Of course he practiced on something old to make sure to get the right sized hole.
He then drilled the holes from inside the car cause the drill wouldn't fit in the engine bay.
Inserted the rubber grommets and hoses.
Old Jul 24, 2010 | 01:27 PM
  #326
looks good. did you seal up the bare spots under the grommets were the drill exposed steel? fingernail polish would work.
Old Jul 24, 2010 | 02:24 PM
  #327
CamaroBeau's Avatar
Be careful please... I think thats dangerous
Old Jul 24, 2010 | 02:27 PM
  #328
dont have to shave his legs that way.
Old Jul 24, 2010 | 06:23 PM
  #329
orocker's Avatar
December 2011 ROTM
Umm sortof. I put it around the one that was open and smeared it in behind the other 2 grommets. But thanks for the tip.
Now we got the condenser and dryer mounted. Also figuring out all the layout for the hoses cause the Squid's brother is coming by tomorrow with a crimping tool to attach all the hoses permanently.
Old Jul 24, 2010 | 09:31 PM
  #330
Scooch's Avatar
Super Scooch
January 2009 ROTM
Wow O... just wow. your camaro is gonna be awesomeness. Im so jealous. you and the squid keep up the good work.
