1967 RS Camaro Project
Old 05-27-2010, 12:43 PM
BigJCamaro67's Avatar
My new rims and Tires are 18" front and 20" for the rear. My question is will the rear tires fit??? They are 285's.
Old 05-27-2010, 01:40 PM
Ok so I have 10 post's, now I can give you some pics. I will take more here in the next few days.
Attached Thumbnails 1967 RS Camaro Project-67-camaro-back.jpg   1967 RS Camaro Project-67-camaro-inside.jpg   1967 RS Camaro Project-67-camaro-side-2.jpg   1967 RS Camaro Project-67-camaro-side.jpg
Old 06-18-2010, 12:09 AM
So I took the subframe to the powder coaters and had it sand blasted, I brought it home before it was powder coated to try and do some better welds. I thought I could save it, but I was wrong. I think it would take to much time to sit and weld on it. Rear mounts rusted out and someone scabbed some metal on them to fix it. Front body mounts rusted out their fix was better than the rear. Here are some pics of what it looks like.
Attached Thumbnails 1967 RS Camaro Project-img_0401.jpg   1967 RS Camaro Project-img_0400.jpg   1967 RS Camaro Project-img_0399.jpg   1967 RS Camaro Project-img_0402.jpg   1967 RS Camaro Project-img_0403.jpg
Old 06-18-2010, 12:14 AM
Here is a pic of a spot underneath the engine brace that had a small hole with some severe pitting and I repaired it by welding several beads over the thin metal and the hole and ground it down. Thought it looks pretty good, just not sure if I want to try to piece the frame back together.
Old 06-22-2010, 11:54 PM
juggernaut's Avatar
Nice to see another banana boat owner lol. Here's a nice wheel survey http://www.pro-touring.com/tech/wheels/Wheel_Survey.htm It may help you get an idea of what will fit. Also, search pro-touring for the "evade camaro". This guy has the widest tires and rims I've been able to find on a 1st gen. without tubbing.
Old 05-16-2011, 05:53 PM
Default Update
It's been awhile but I finally decided to take it to the sandblaster and find out how much work really needed to be done. Ended up spending about $5,000 on the remainder of the body work back in december time frame. I got body work finished, the body acid primed and got the inside, trunk and underneath of the car coated with heavy duty industrial paint. Now I'm starting to put it back together and I noticed that my upper control arm shafts do not match. I have to different shafts. Ones more rectangular/square than the other which is circular around where the bolts go through the subframe. Trying to find out where I might be able to get a used shaft for a 67. Any suggestions would be appreciated. I'll try to get some pics posted.
Old 05-21-2011, 04:44 PM
shevrolay's Avatar
Hard to stuff an A-body Person into an F-Body Car...better invest in some knee-pads.
Old 08-29-2011, 11:56 PM
Here are some pics after the body work was done and I put the subframe on. I took some pics right after sandblasting but I can't find them right now.
Attached Thumbnails 1967 RS Camaro Project-camaro-front-resized.jpg   1967 RS Camaro Project-camaro-driver-side-resized.jpg   1967 RS Camaro Project-camaro-back-resized.jpg   1967 RS Camaro Project-camaro-passenger-side-resized.jpg   1967 RS Camaro Project-camaro-trunk-resized.jpg
Old 09-24-2011, 01:16 AM
RestoringMy68's Avatar
Looking forward to reading more about your progress! I'm 6'4" so I know where you're coming from!
  #20
Old 09-24-2011, 07:23 PM
Rottn1's Avatar
I too will be following this thread, please keep the updates coming .
rwolf15241
12-14-2013 10:48 AM
rwolf15241
12-12-2013 06:22 PM
wnarunm
03-12-2012 09:49 AM
fountjr
05-06-2009 08:21 PM
cookkr
08-21-2008 11:31 AM
Quick Reply: 1967 RS Camaro Project
