Replacing a heater core in a '67 w/air
Old Aug 6, 2013 | 11:55 AM
ragtag's Avatar
Default Replacing a heater core in a '67 w/air
The RS I just bought has a bad heater core. After looking at its location it looks like I have to remove the front fender or is their a simpler way? Thanks for any tips.
Old Aug 6, 2013 | 12:41 PM
The heater core comes out from the inside of the car. But on A/C equipped cars (pretty sure yours is like the 69), removing the mounting nuts from the studs on the fender side require you to remove the inner fender, or drill an access hole. You may or may not want to drill a hole in your inner fender. A question, do you plan on using the heater? I bypassed, and eventually removed my heater core since i don't drive the car in cold weather.
Old Aug 6, 2013 | 02:33 PM
ragtag's Avatar
Thanks for the reply Camaro 69. Since I live in mid-Michigan it gets very cold traveling to some of the fall shows so I need a heater. I guess I'll just have to bite the bullet and tear it apart.
Old Aug 7, 2013 | 09:35 PM
randf's Avatar
that's really odd. I just replaced the heater core on my 1967 RS last weekend. It was more trouble than I expected. The front clip of my car was already off.
I used these instructions: http://www.worldwidecamaroclub.com/p...atcorerepl.pdf
Old Aug 8, 2013 | 08:40 AM
ragtag's Avatar
Thanks for the link randf. I appreciate your help.
pmnj19
Nov 16, 2011 11:37 PM
2kMaro
Nov 12, 2011 06:30 PM
pmnj19
Nov 1, 2011 10:42 AM
69hugger
Aug 7, 2008 07:56 AM
mike86rs
Mar 13, 2006 11:29 PM
