Deluxe door panel 67 Camaro
Old Jul 1, 2017 | 07:08 PM
Milan's Avatar
Default Deluxe door panel 67 Camaro
Can you mount a deluxe door panel on a standard door? Is the door handle and window crank in the same location? 67 Camaro
Thank You
Old Jul 1, 2017 | 07:14 PM
Y2K's Avatar
Y2K
I'd be very surprised if they weren't. You could call Camaro Central, they sell both and should be able to tell you. https://www.camarocentral.com/
Old Jul 8, 2017 | 10:23 PM
67camRSSS's Avatar
Should be the same door just different panel, be aware the new custom deluxe door panel is much thicker than the original. I had to pry the upper chrome trim carefully all the way across to open the gap prior to installing. Also the door handle is a pain to install inside the pocket I made an Allen wrench that slipped in to a nut driver to install easier. Looks great just takes time and patience. Should have 2 sets of 2 snaps on the sides of the panel to press into the door and then I believe 5 screws on the bottom to hold it in place. Make sure the window crank does not touch the panel as well or it will rub through your new panel. Did that on mine accidently.
harley rider
Jul 25, 2013 11:31 AM
Drew727
Jul 30, 2010 10:31 PM
jgt
Nov 18, 2009 11:25 AM
