67camRSSS |
07-08-2017 10:23 PM |
Should be the same door just different panel, be aware the new custom deluxe door panel is much thicker than the original. I had to pry the upper chrome trim carefully all the way across to open the gap prior to installing. Also the door handle is a pain to install inside the pocket I made an Allen wrench that slipped in to a nut driver to install easier. Looks great just takes time and patience. Should have 2 sets of 2 snaps on the sides of the panel to press into the door and then I believe 5 screws on the bottom to hold it in place. Make sure the window crank does not touch the panel as well or it will rub through your new panel. Did that on mine accidently.
