69 Headliner Install with all Glass in place
Old Nov 10, 2021 | 10:57 AM
redmidyear's Avatar
Default 69 Headliner Install with all Glass in place
Guys,
Does anyone have a video or know where I can get one for headliner installation in a 69 Camaro? All the videos I find has the windshield and back light removed.
Any help is greatly appreciated.
Larry
Old Nov 10, 2021 | 03:11 PM
Everett#2390's Avatar
Headliner can be installed without window removal.
The rods across top should be labeled front to back and holes in roof structure marked so rods go back into same holes for a tight liner.
Remove moldings about windows, old liner with rods,, place rods into liner and then into holes, then using fingers, wrap liner around the edge for fastening onto tabs. Pull corners snug first onto tabs.
Let liner bake in sun for a couple hours before installing. Fingers will be sore.
Old Nov 10, 2021 | 04:37 PM
redmidyear's Avatar
Thanks. I appreciate the info. I wasn't sure how it attached when pulled. tabs or glue?
Old Nov 15, 2021 | 05:41 AM
There are tabs and I believe the Fisher Body Manual has glue for there also. But I did not use any.
Just pulled fabric, bend around the edge, then press onto tabs. You may have to trim length of liner.
Mike McClaran
South West
Aug 4, 2013 09:42 PM
Barnstang
Jun 16, 2009 11:34 AM
az_uncledonny
Jul 14, 2008 06:30 PM
dbarkley
Aug 30, 2007 08:06 AM
Buckles
Dec 4, 2006 03:36 AM
