67 side view mirrors
Old Feb 8, 2019 | 01:32 PM
Derrickx1's Avatar
Default 67 side view mirrors
Hi guys. I have a 67 ss/rs and here’s my issue. Every time I close the doors the side view, door mounted mirror moves. It’s totally tightened down but the round mirror part moves when the door closes. The ball is tight but I think the weight of the door is causing this. Im
at the point of changing the mirrors but I wanted to try and keep the original looks of the car. I do like the modern style
mirrors and thought about putting the 70’s gm color coded egg style mirrors to replace them. What do you think.
Old Feb 8, 2019 | 09:08 PM
Zspoiler's Avatar
Pictures?
Old Feb 22, 2019 | 11:39 AM
Al Loyrat's Avatar
I fixed the factory mirror on my 69. Take the mirror off the car and soak the mirror head in lacquer thinner for about 20 min. Take a 90 degree pick and carefully pry the glass off over a soft cloth (glass is held in with black RTV). Some used screws and some had peened rivets, mine has rivets. Peen the rivets with a small peen hammer. If screws, remove 1 screw at a time, clean threads apply some locktight and screw it in tight, then do the other screw. Clean off old silicone, apply fresh black silicone in the same areas.
Old Feb 22, 2019 | 12:51 PM
Derrickx1's Avatar
seems like a lot of work but I do appreciate it. Thanks
darrellv
Feb 4, 2013 12:30 AM
redride
Dec 29, 2012 10:50 PM
Z28Camaro98
Dec 21, 2012 11:18 PM
rollermotor
Apr 20, 2007 09:11 PM
350rs
May 23, 2006 11:32 PM
