67 kick panel issue.
Old Sep 13, 2015 | 06:50 PM
Bigdog_77's Avatar
Default 67 kick panel issue.
I am in the process off gutting my 67 Camaro to send it out for mefia blast. My kick panels have the air vents that are extended into the side wall. Is there some trick to removal?
Old Feb 19, 2020 | 10:11 AM
Big Ern's Avatar
The factory used ( a lot !!! ) of putty to seal that vent. there isn't anything but the putty and the 4 screws holding it in. Be careful not to break the extension off. I put Vintage air in mine, but was hoping to leave the vent working, but wound up sealing it up and using the kick panels with the speakers included. I found that there wasn't enough clearance for the emergency break pedal to pass the speaker. I cut the pedal pad off and re-welded it closer to the inside.It is still close, but it works.
Mike68396
May 26, 2020 11:24 AM
timcordrey
Feb 19, 2020 10:26 AM
camaro396
Aug 2, 2015 09:00 AM
moparmusclecars
Feb 1, 2014 06:32 AM
mpvette
May 8, 2009 11:00 AM
