Big Ern |
02-19-2020 10:11 AM |
The factory used ( a lot !!! ) of putty to seal that vent. there isn't anything but the putty and the 4 screws holding it in. Be careful not to break the extension off. I put Vintage air in mine, but was hoping to leave the vent working, but wound up sealing it up and using the kick panels with the speakers included. I found that there wasn't enough clearance for the emergency break pedal to pass the speaker. I cut the pedal pad off and re-welded it closer to the inside.It is still close, but it works.
