67 rs headlight motor problem and question
Old Jan 1, 2011 | 04:16 PM
bbar's Avatar
Default 67 rs headlight motor problem and question
Hi,
Have a 67 rs Right side headlight motor will not open or close. All limit switches, diodes, etc. are fine. Need to test motor. Motor pigtail has 2 wires. Do I remember right that I put 12 volts to it and hooked up one way, it goes one way, hook up the other way, it goes the other? I think the motor is frozen. See grease has leaked out onto motor plate. These are repro motors I put in when I built the car 14 years ago. Thank you
Old May 24, 2020 | 11:54 AM
Big Ern's Avatar
hook hot to one and ground to the other / then reverse the wires. One way they should open , then close the othe way.
gmshadow
Feb 2, 2021 10:22 AM
ZL1
May 16, 2016 05:04 PM
bbar
Jan 2, 2011 06:45 PM
Butch67
67-69 V8 Tech
Oct 12, 2010 07:24 PM
davidlee
Oct 7, 2006 02:48 PM
