what every first gen owner should have
Old Apr 25, 2007 | 02:41 PM
dbx's Avatar
dbx
Default RE: what every first gen owner should have
When I was a teen, I had to strike my starter almost every time I used this one car I had. The reason is usually that the bendix (sp) is going out. Although, I've used the same mthod with a riding lawn mower in which the starter was not old. Yep, a hammer is a great tool
Old Apr 25, 2007 | 05:38 PM
a356708's Avatar
http://i108.photobucket.com/albums/n...ansonly003.jpg
http://i108.photobucket.com/albums/n...ansonly005.jpg"
http://i108.photobucket.com/albums/n...ansonly007.jpg"
http://i108.photobucket.com/albums/n...ansonly002.jpg"
http://i108.photobucket.com/albums/n...ansonly008.jpg"
Can you guyshelp me identify these wires on the harness to where they go to where they come from on the fuse box.And where they should go too
The alternator is external but i want to make shure i have the conversion correct.from generator.Also for for the hei distributor from points .
It used to be a 6 now a v8 I think the wiring should be the same again it is a 1968.Thanks guys I want to make shure i have all the correct wiring before i start beating on the starter .
Old Apr 25, 2007 | 07:12 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
You dont need to respond to the PM, I can see it now. I am having similar issues with finding a wiring diagram, apearantly they are hard to come by. I will let you know when I find one.
Old Apr 25, 2007 | 10:55 PM
a356708's Avatar
Can anybody help me with this ? All i need is the wiring to get this thing going
Old Apr 26, 2007 | 01:34 PM
a356708's Avatar
Hello i just checked the starter and its just fine but it seems its not strong enough to turn the fly wheel .
for the wires so far i found this
purple is switch it is the wire that cranks the starter
pink is key on
white wire is the resistance wire
yellow was the wire that goes to the coil in the old points ignition
Old Apr 26, 2007 | 01:38 PM
a356708's Avatar
what is orange ?
light blue
dark blue
blue
black
Old Apr 26, 2007 | 04:22 PM
1969 SS's Avatar
second pic is too blurry but as far as the first one goes if you're not an A/C car
purple: S on starter
pink: coil?
yellow: from starter to coil
black: ground
lt. blue: there is a light blue wire that usually goes to the wiper motor
white: regulator to alt
orange: usually goes to the alt after splicing in with the red wire coing from the regulator
blue: right turn
lt. blue: left turn
I hope this helped a little. it is kind of hard to tell with them all being so short. usually the length of them helps out a lot
Old Apr 26, 2007 | 11:56 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
So, does anyone actually have a wiring diagram for a first gen? One you could post or a link?
Old Apr 27, 2007 | 06:38 AM
1969 SS's Avatar
I have a couple of different,full schematics andmanuals for everything 69 but they wouldn't photo well. there are a few different ones for different optioned cars
I think you should be able to buy them these days but I'm just to lazy to look because I already have them
mine are from 1983.Jim Osborn Reproducions and the phone # is/was 404-962-7556
probably worth a try
Old Apr 27, 2007 | 09:07 PM
  #20
a356708's Avatar
tHANKS BUT IAM GOING TO GET THIS GUY WHO HAS DONE THIS SET UP I WILL TRY TO GET ALL THE WIRING AND MAKE SET UP AND POST ONCE HE DOES IT
.BY THE WAY .HOW WIDE ARE THE RALLY STRIPES ON A CAMARO ? THANKS
