Valve Covers
Old 08-10-2010, 08:48 AM
69Muscle's Avatar
Hey burnt 68. Anychance u can get a pic of that. I don't see it on mine, the Holley site says some have it some don't. As far as spacer, the is a spacer on there now for clearance reasons, but no port.
Old 08-10-2010, 08:54 AM
69Muscle's Avatar
Hey burnt68, any chance you have a pic of that. I don't see it on mine, but then again the holley site says not all have it. As far as spacer, there is one on it right now for clearance issue i had, but no port.
Old 08-10-2010, 09:04 AM
69Muscle's Avatar
having some internet issues, not sure if this posted, sorry if it already has. Burnt68, any chance u have a pic of that port. I don't see, but Holley website says not all 4150's have it. Also, mine has a spacer currently, but no port.
Old 08-10-2010, 09:37 AM
Originally Posted by 69Muscle
Yeah, i plan on seeing the diff when hooked up directly. I'd prefer to do that, but then what the heck do I do with pcv since I don't seem to have a vacuum port on the carb? If the answer is that I have to tee it. Would it be better to do that with a fitting that splits it at the intake versus the way it is now (hose coming off single fitting on intake then a hose off splitter to pcv and hose off splitter to booster)
I'd have to see a picture or drawing of what you're describing. Are the pcv and booster connected in series? If your only option is to connect them to the same vacuum source, it's better to have a tee at the manifold, then split off separately from there.
Old 08-10-2010, 10:13 AM
69Muscle's Avatar
You got it dude. One vacuum source on intake has a hose to a splitter then two hoses off that (one to pcv, one to booster). Unless i can hook pcv into aircleaner or somwhere else since carb doesnt seem to have a port, this may be my only option. And if so, I think it would be atleast better to have the fitting on the intake with two nipples, than one nipple and a splitter inline off that hose (as it is now). What do you think? Ideas?
Old 08-10-2010, 11:36 AM
My thought about not daisy-chaining them together was so that you wouldn't take chances of getting any oil contamination near the brake booster. I would still want my booster getting full vacuum on it's own dedicated connection, even if you had to install a carb spacer with a vacuum port for the pcv, as already suggested.
Old 08-10-2010, 12:36 PM
69Muscle's Avatar
Cool, thanks. Is there a torque spec for valve covers for my 350? I have the 4 bolt, not the center bolt.
viperffx
10-11-2010 09:57 PM
rockstarbass1
82-92 V6 Tech
11-02-2009 10:23 PM
SSPOWER
04-28-2008 02:48 PM
blink18236dude
03-16-2007 01:48 PM
nnickty
08-22-2006 02:25 AM
Quick Reply: Valve Covers
