turn signal issue
Old Aug 17, 2022 | 01:39 PM
jsharp006's Avatar
Default turn signal issue
I have a 1969 Camaro that I changed over to all LED bulbs. I changed to a no-load flasher module, but the front turn signal don't work if the running lights and/or headlights are on. If turned off then they work. I'm puzzled...and it won't pass inspection. Any ideas? Thanks! James
Old Aug 19, 2022 | 05:36 AM
Everett#2390's Avatar
Install a P/N 552 flasher.
Alternator is working?
Old Aug 19, 2022 | 09:32 AM
red42's Avatar
Jsharp,
Most likely, you have corrosion in the light fixture itself, or a bad ground there. Check the grounding by clipping on a temporary ground wire, and see if that fixes things. If the fixture is corroded inside, you may be able to get a pre-wired new fixture from NAPA (or others). If the grounding is shaky, run a new dedicated ground wire from a solid ground point to the fixture, right on top of the existing ground wire. Keep us posted.
Old Aug 19, 2022 | 02:03 PM
jsharp006's Avatar
thanks! will take a look
Old Aug 19, 2022 | 02:04 PM
jsharp006's Avatar
thanks for the reply. alternator is good. I will try a 552 flasher and new incandescent bulbs.
Old Aug 23, 2022 | 10:51 AM
jsharp006's Avatar
Ended up being the wiring. Had installed aftermarket turn signals and had to switch the polarity and now they work!
ClintGard
Apr 21, 2021 09:50 AM
PushrodLSX
Dec 27, 2017 06:58 AM
msp1055
Jun 1, 2014 08:11 PM
nnewquist
Feb 18, 2012 09:55 PM
dustinb
May 1, 2008 06:27 PM
