Trying to remove seat pan in floor,HELP
I am tring to install a rear half floor pan in. I can't get the seat pan out?? I drilled out the spotwelds around the perimeter andit still won't move? Any suggestions or am I missing something?Thanks
I think you are going to have to cut them all the way out. Angle grinder or plasma torch. If not I hope someone on here has a better idea because I am going to have to do the same thing this spring and thats how I plan on it.
cut them out with a cut off grinder.that way you dont warp the metal.leave about 1-2" to give you something to weld to.i set the pan inside the pan i was fixing to cut out and chalked a line all the way around it,removed the new pan.then i went about 1 or 2" above that line and this gave me plenty of metal to weld to.it was a little bit of a tight fit,but once you got them in there they were snug and ready to weld.
