trying to put gas pedal and linkage back together
ok i need a reference photo of how it originally looked......I have a 68 camaro im putting together i got the engine running and timed, thats all good now im moving to the brakes but before that i have know make sure it looks like original from the gas pedal to the carb how does it hook up and how does it look i cant find any reference photos.....any help much appreciated
Starting at the gas pedal on engine side, the rod slips into the lever from the pass side, then a washer goes on, then the clip/cotter pin keeping it in place.
At the carb, two ways, a rubber bushing with a nylon bushing fits in the large hole. The rod enters from the drvr side, washer and clip/cotter pin. Or, drop down the next smaller hole and insert the rod.
Hold carb at WOT, pedal to the floor, and adjust the carb pivot to slip into the bushing. Attach return spring and ensure throttle does not hang up at WOT.
