Trunk Pan Replacement
Old Oct 15, 2010 | 08:35 AM
blee62's Avatar
Default Trunk Pan Replacement
I am replacing the whole trunk pan and the whole frame rails on both sides. Is it easier to install frame rails while the trunk pan is out? Does anybody have specs on the location of frame rails? I am also replacing the whole floor pan. Where should I start first? Any help would be appreciated.
Thanks,
Bill
Old Oct 15, 2010 | 12:01 PM
hkunz's Avatar
I'd be cautious on removing too much at one time. When I tubbed mine (back in the 80's) the whole package shelf dropped an inch when the steel wheelhousing came out. The last cut, and it snapped the saw blade right off, with me laying in the trunk. You remember those kinds of things.
If you are getting a replacement part for the trunk, I'd do the floor first, then go to the rails, unless you have a solid way to lock it in place during the whole process.
CZimmer
Jun 3, 2012 01:25 AM
anthonys95
Sep 5, 2010 01:45 PM
hoffmandirt
Jun 11, 2008 07:05 AM
RUQWKNF27
Apr 3, 2008 12:57 PM
camaraddict
Jan 23, 2008 07:02 AM
