Temp Sender/Gauge Question
Old Mar 3, 2015 | 09:10 PM
Icecobra's Avatar
Your engine should reach a minimum temperature as well as a not to exceed temperature. The engine will run less efficiently and can cause problems with internal components. Modern cars run around 230 degrees and with modern coolant its what they are designed to run. So what about older cars, your still shooting for the magic number of around 210 (but it runs less) and should run a thermostat of around 200 to achieve that. If your having cooling issues and your having engine temps you can not easily maintain then you may have radiator cooling and or flow issues. I like mine to get warm and then stay there it helps the engine run better and cleaner..
Old Mar 4, 2015 | 09:05 AM
flat tire's Avatar
Up to 5 degrees more (in your instance anyway) is still 5 degrees. But why run the engine so cold though? The pistons, rings, and bearings are designed to expand (all at different rates) when they reach running temperature. 160 isn't yet up to the temperature those components were designed to be run at, so running it colder like that can do an engine more harm than good.
you will have to take that up with united racing engines in Az.
they are the ones who built the engine and that is what they recomended
Mitch Upton
67-69 V8 Tech
Sep 9, 2011 04:04 PM
josh95camaro
Oct 9, 2009 10:15 AM
bezerker
Apr 27, 2009 05:07 PM
Diablo87
Apr 20, 2008 09:13 PM
prplcat
Dec 29, 2007 09:01 PM
