Sub Frame and sway bar
Old 05-14-2020 | 02:33 PM
Robb Sheldon's Avatar
Lightbulb Sub Frame and sway bar
Hello,
Anyone purchase Chris Alston's g-Connector System for OEM Sub Frame. It is used as a sub frame connector and sway bar unit in one. The purpose is to stiffen up my chassis, and eliminate body roll and float on my 67 rs. I will also be adding Chris Alston's 1" Front sway bar. The 67 will be a moderate street/cruise car. I might take it to the strip once or twice for the 1/4 mile for fun. Starting with Chassis, then transmission/rear end, afterwards a moderate cam and intake upgrade to the 327.
Thank you in advance
Old 05-19-2020 | 11:28 AM
skypuppy's Avatar
Seems like a cool addition - not much of a write up on it for Camaros but looks very straight forward, and it doesn't seem to impede the task of removing any part of the drive train. There seems to be a few variations of it:
https://www.classicindustries.com/product/k5904610.html
https://www.cachassisworks.com/p-159...-subframe.aspx
Old 05-19-2020 | 11:58 AM
SoCal67's Avatar
Don't know anyone running one. For a street or occasional 1/4 mi car it seems a bit overkill. AutoX or convertibles would likely see the most benefit.
For Op's noted use standard sub frame connectors and a 1 1/8" sway bar should give him noticeable improvements for his described use. It did for me. I bought Summit brand. Considerably less $ than Chassisworks set up
For 1/4 mi use we would typically disconnect front sway bar end links to help transfer weight towards rear on the launch if running a front bar
Old 05-23-2020 | 04:58 PM
Thanks for the tip. With the saved $, I can invest in front and rear sway's.
ATM
07-04-2013 09:52 AM
Anthony k
07-26-2012 09:37 AM
wantvegas
05-23-2011 03:54 AM
uestraven
70-81 V8 Tech
12-10-2009 11:24 AM
1989_RALLYSPORT
11-21-2009 09:56 AM
Quick Reply: Sub Frame and sway bar
