Speedometer Gauge
Old Feb 7, 2015 | 02:36 PM
stewie's Avatar
Default Speedometer Gauge
Does anyone know why my stock 69' speedometer gauge reads 100mph when I'm going 50mph.And gas gauge doesn't work..
Old Feb 8, 2015 | 12:08 AM
Someone may have put lower gears in the rearend and not changed the drive/driven speedo gears in the trans to compensate. Or someone may have changed the speedo gears (wrong ones) in the trans for whatever reason. Your gas gauge is an unrelated issue. Either a bad gauge, sending unit, or related wiring.
Old Feb 8, 2015 | 06:50 AM
stewie's Avatar
Thanks for your help I will begin my new trouble shooting....BTW alls well on the negitve grounding issue,dual fans are running well,took the car out for a local cruise drove about 60 miles in town.I live in Scottsdale it was 82 degrees and temp gauge stayed between 195/205..I did notice though when fans kicked on when I was at at stop light the cars idle slowed down a bit..
Old Feb 8, 2015 | 10:45 AM
Icecobra's Avatar
Do you need instructions to help with testing fuel gauge?
Old Feb 9, 2015 | 07:01 AM
stewie's Avatar
Yes please! Thanks
Old Feb 9, 2015 | 09:52 AM
Icecobra's Avatar
performing the test then the problem is from the trunk to the gauge...
Old Feb 9, 2015 | 11:06 AM
hellrazaa
Jun 9, 2014 05:45 AM
DDRDiesel
Apr 19, 2012 11:44 AM
SA_Adams
Feb 24, 2009 09:06 PM
dbx
Jun 16, 2007 11:39 PM
creed777
Mar 20, 2007 01:09 AM
