Speedo doesn't work
Old Nov 11, 2022 | 12:59 PM
PaulRed1967's Avatar
Default Speedo doesn't work
Hello,
I own a relatively low-mileage 1967 Camaro (64,00 miles). The odometer works fine but the speedometer does not. I've replaced the cable, so that's not the problem. I'm wondering if there is a way to fix the speedo WITHOUT losing the low-mileage number? Is there something that can be fixed/ replaced in the back of the gauge without disturbing the mileage? Thanks in advance!
Old Nov 11, 2022 | 07:24 PM
If it's not somehow documented I'd find it hard to believe a '67 has only 64K original miles and the speedo quit working.
It may have spun over 100K and back to zero once or twice in 55+ years but
there are shops that do speedo repair and I think you may be able to order a new one with the same mileage.
Good luck to you.
Old Nov 13, 2022 | 03:31 PM
SoCal67's Avatar
real milage aside, there are places that repair these Speedo's. Given the odometer works, the cable is turning the speedo...likely bad gear in speedo
Old Nov 14, 2022 | 07:28 AM
manicmechanic007's Avatar
The speedo works using tiny rotating magnets and the speedo shaft has to move freely
Yours if sitting forever hence the low miles, it may just be sticky or frozen
Pull the cluster or otherwise get to the speedo and try freeing up the shaft
Then send it to a place like Speedo Tach for repair if you cannot get it working
Old Nov 14, 2022 | 07:53 AM
You can tell mileage by the pedals, seats and carpet, not just the odo
My boss 302 only has about 56k on it
Gregt909
Aug 29, 2015 03:42 PM
stox58
Mar 1, 2011 08:41 AM
korben dallas
82-92 V8 Tech
Jan 3, 2011 07:51 PM
My83Z
Jul 7, 2007 09:56 PM
pistolpete_67
Feb 23, 2007 11:52 PM
