Removal of 69 Rear Seat
Old Apr 9, 2010 | 10:58 AM
69 Conv's Avatar
Default Removal of 69 Rear Seat
This should be easy. How do I remove the rear seat in my 69 convertible. Thought I would ask before I broke something trying.
Thanks.
Old Apr 9, 2010 | 01:00 PM
There are hook catches (one on each side) that holds the seat portion to the floor. You push the base of the seat, by the bottom frame, towards the back while lifting at the same time. It's under tension, so you need to use a little horsepower. Sometimes kicking it with your knee helps.
The backrest is bolted (2 bolts) to the rear bulkhead at the base, you'll see it once the seat is out. Remove those and slide the back straight up to unhook it at the top.
Old Apr 9, 2010 | 08:50 PM
69 Conv's Avatar
Thank you very much.....
wesman98
Sep 1, 2013 09:08 AM
shaun91
Apr 23, 2011 05:08 PM
yzair
Apr 7, 2011 06:09 PM
kellyw66
May 1, 2007 10:59 PM
HaloNick
Nov 16, 2005 11:33 AM
