Rear End Swap and Wheel size???
Old Mar 31, 2009 | 03:18 PM
Chads427's Avatar
Default Rear End Swap and Wheel size???
I have a 68 camaro and who ever had it before the person i bought it from put a Dana 60 rear end in it with a 4.56 gear. I am looking at going more to a street/strip set up with a pro touring car look (lowerd!) Anyways i have a two part question, I have priced a 12 bolt rear end at a local salvage yard out of a 73 truck. Will the 12 bolt fit as far as width under the camaro? Also i want to run the widest wheel/tire combo i can on either 18s or 20s, without tubing. So what would that be? Thanks for your imput.
Old Apr 6, 2009 | 05:18 PM
dasvagmag's Avatar
That should work man I put a 70 chevelle rear end in my 69 its a 10 bolt but about the same size as a 12.. I dont have big rims but I fit 295 65 15 to give you an idea...
Old Apr 7, 2009 | 01:10 AM
lt4weeda's Avatar
The rear end should fit length wise. but the spacing for the mounts on the dana axle vs. the 12 bolt will be different. Hopefully you have a welder or know someone who can weld it for you. I have some 10" wide rims under my 68, but then I also have a narrowed 9" as well.
vonwisdom
12
Sep 4, 2012 01:02 AM
numskull223
Sep 5, 2011 10:56 AM
Maro14
Aug 11, 2011 09:38 AM
Beauespirit
Oct 31, 2009 11:54 PM
docd
Oct 23, 2007 05:31 PM
