Radiator Restoration Query
Old Sep 29, 2018 | 01:30 PM
Tommy68's Avatar
Default Radiator Restoration Query
Hi Camaro owners:
I'm having my original 2-core Harrison radiator restored. It's in pretty rough shape. The radiator was stock with my 1968 2d Camaro MT no a/c 327. The individual doing the restoration said he cannot reuse the original upper and lower brackets. I'm not sure if that's correct and would appreciate any expert guidance. I'm going for originality in the restoration. Many thanks.
Old Oct 6, 2018 | 04:20 PM
ryanmaple's Avatar
Where are you located? I just Had my radiator restored and he took off the old upper and lower core brackets and reused them, the new cores do not have the harrison holes to hang and paint. he did a great job, can send you before and after pics, PM me and I can give you his name and number.
Old Oct 6, 2018 | 08:02 PM
Everett#2390's Avatar
The brackets are soldered onto the tanks, radiator does not set in any cradles.
Old Oct 7, 2018 | 03:53 PM
ryanmaple's Avatar
Cradles? he showed me new core it had flat with no holes in support brackets top and bottom he unsoldered the new and replace with old so it looked like it did when it let harrison. bumped out all dents from the tanks put everything back on, painted and pressured tested. picture is after recore. question do you know how they ran the wiring in a 67 coupe from the trunk to cabin, I mean from the factory? Thanks!
Old Oct 7, 2018 | 05:17 PM
Al Loyrat's Avatar
No upper and lower mounting brackets on gen 1 Camaros from the factory.
Old Oct 7, 2018 | 07:13 PM
From RockAuto: see the sides for bolting
https://www.rockauto.com/en/moreinfo...321243&jsn=440
Shadyredeyes
Dec 29, 2017 06:44 PM
birkenmeyer68
67-69 V8 Tech
Sep 30, 2008 07:40 PM
Harvey
May 12, 2006 03:27 AM
89RScammy
Apr 18, 2006 01:14 AM
