Question about shifter
Old Nov 24, 2018 | 03:59 PM
1967Fan's Avatar
Default Question about shifter
All, I am new to the forum and had a quick question. I have an old school 67 with a 4 speed Muncie M20 with an older Hurst shifter. It’s pretty loose feeling for lack of a better term. Are there any suggestions on a newer shifter and linkage that would work with this transmission that would tighten things up a bit.
Old Nov 24, 2018 | 04:45 PM
Y2K's Avatar
Y2K
You can get rebuild kits for Hurst shifters, there's also videos of "how to" but they're pretty simple.
Old Nov 26, 2018 | 09:24 PM
Al Loyrat's Avatar
The shift rods have nylon hat bushings at each end that wear out. Hurst sells a kit with hat bushings in nylon or steel & new spring clips. If you go with steel, you'll want to keep them lubed.
Old Dec 1, 2018 | 02:49 PM
1967Fan's Avatar
Thanks all for the responses.
downundercamaro
Jun 29, 2019 07:57 PM
ahaas2011
Feb 7, 2018 07:04 PM
aldistuck
Jul 11, 2014 08:52 PM
Gregt909
Jan 2, 2014 04:49 PM
Don Hog
Oct 30, 2005 02:35 AM
