Proper Lifting instructions (4 wheel off ground)
Hey All,
looking for advice for for using a hydraulic floor jack and jack stands to lift a 67 camaro.
I have never lifted a sub frame car before and I am doing a disc brake conv. and some other things so i need to get all 4 wheels off the ground.
not sure of the proper way to do this on a 67 camaro and could use some advice.
I would put jackstands under the axle to support the rear and under the subframe behind the front wheels. If a garage where to use a lift they would put the rear legs under the front leaf spring mounting point.
![Name: 12boltrear.jpg
Size: 38.2 KB](https://camaroforums.com/forum/attachments/67-69-general-43/28550d1501310510-proper-lifting-instructions-4-wheel-off-ground-12boltrear.jpg)
![Name: SANY0563.jpg
Size: 49.1 KB](https://camaroforums.com/forum/attachments/67-69-general-43/28551d1501310510-proper-lifting-instructions-4-wheel-off-ground-sany0563.jpg)
Here's how I do it. I jack it up where the red arrows are, directy under the engine on the crossmember and under the diff. I jack the front first because lifting the rear end first will cause the nose to drop and I can't get a jack under the valance. The bassethound isn't required.
Note: make sure the jack can roll while jacking so the car doesn't slide off the contact plate.
Yes it is. Lifting the car like that is gentle compared to what the rearend is subjected to when driving the car.
I always jack my cars up the same way juggernaut showed.
![Wink](https://camaroforums.com/forum/images/smilies/wink.gif)
Thanks everybody
I am doing a 4-wheel disc converstion, Header install, U-Joint replacement and a exhaust system so seems like anywhere I install the stands they eventually will be in the way but I will deal with that
so
lift front first via crossmember.
lift rear via rear end
place stands under rear axel and frame behind wheels
and GO!
so
and GO!
