no signal lights
no signal lights
I just finished installing LED taillights in my 69 Camaro that I purchased from Summit Racing. Everything works except the signal lights. I replaced the flasher with an electronic one. What could be wrong? Thanks in advance for your help.
Flasher on fuse panel is for emergency flashers.
Does the selected side come on, but no flash?
Ensure electronic flasher is grounded good.
Ensure it has power from fuse panel.
Might try a heavy duty P/N 552 flasher.
OE turn flasher is above the gas pedal either hanging from the harness or in its clip.
If signal lights come on and no flash, try a heavy duty flasher, p/n 552, as it flashes on its own and does not need a load the work.
