New 69 owner
Old Jul 3, 2015 | 05:48 PM
Oldschool69ss's Avatar
Default New 69 owner
Hello Im new here maybe you can give me some good advice. I have a 69 with a 383 stroker motor I need to replace the radiator my question is im thinking of putting a 396 over the winter so I want to get a good radiator that will work now with the small block and still not have to replace it when I change over to the big block any suggestions will be very helpful thank you
Old Jul 4, 2015 | 05:33 AM
flat tire's Avatar
I have a Champion 3 core that is rated to cool 600 HP. it cools my 500+ sb without any problems
I hope you realize that going from sb to bb will require a lot of changes and parts
Old Jul 13, 2015 | 08:42 AM
Everett#2390's Avatar
Welcome, OS69,
As F/Tire suggests, alot will have to be changed:
Frame mounts for engine mounting,
Trans crossmember to match above
Heater core and fan cover, if heater will be used
Accessory bracketry,
Throttle linkage, maybe
While you're at it, change body bushings to Moroso solid bushings use antiseize on threads.
My70z
Apr 27, 2013 06:43 PM
MastaGunZ
May 29, 2012 02:54 PM
WindyCitySuperSport
Oct 31, 2011 06:48 PM
9434V6
Aug 18, 2011 07:53 PM
EdPDX
Jun 20, 2008 05:48 PM
