Need help on this 69. Z value
Been looking for a real Z for a while. Found this car through a friend of a friend
The car is a real Z and a real black / black coded car
I am pairing what he sent me ..
And the paint is 8/10
Any help with a realistic value would be a huge help!
1969 Z28 X77 Triple Black Car
ST 69 112437 NOR 277684 BDY
TR 712 10 B PNT
02 D X77
FRESH RESTORATION ON THIS BEAUTIFUL Z28
NEW
UNDER BODY:
FULL PIECE FLOOR PAN, BRAKE LINES, FUEL LINES,NEW BODY MOUNTS, FRONT SUSPENSION,
HEIDTS 4 LINK REAR SUSPENSION, US WHEELS, NEW TIRES, REAR DISC BRAKE CONVERSION,
WILWOOD BRAKE CALIPERS,NEW FUEL TANK, NEW FLOWMASTER EXHAUST WITH STAINLESS TIPS
ENGINE AND TRANSMISSION
CHEVY 350 BLOCK BALANCED AND BLUEPRINTED PUNCHED TO 388 625HP
SPORTSMAN RACING PRODUCTS PISTONS AND RINGS MOTOWN 220 64CC HEADS PORTED AND POLISHED
CUSTOM GROUND CAM WITH A #4 AND #7 CYLINDER SWAP, POLISHED HEADERS,VACUUM PUMP
ELITE INTAKE MANIFOLD PORTED AND POLISHED HOLLY ULTRA DOUBLE PUMP 750 CARBURETOR,
EVERY THING FROM AIR CLEANER TO OIL PAN IS BRAND NEW. NEW POWER STEERING PUMP
HIGH VOLUME OIL PUMP, NEW FUEL PUMP, EVERY MECHANICAL ITEM UNDER THE HOOD IS NEW.
NEW TREMEC TKO 5 SPEED TRANSMISSION, CENTERFORCE DFX CLUTCH.
AUBURN 12 BOLT POSI TRAC WITH MOSER AXLES ALL BRAND NEW
NEW DYNA MAT INSULATION, HOUNDSTOOTH INTERIOR, CENTER CONSOLE,REPRODUCTION RADIO
BLACK VINYL TOP AND TRIM INCLUDED (NOT INSTALLED)
2 LARGE BINDERS WITH ALL RECEIPTS
TR 712 10 B PNT
02 D X77
NEW
UNDER BODY:
This car sold on Ebay for $34,600. Probably because it has the X77 in the trim tag. Unfortunately, there wasn't a lot of Z28 left to it. The engine and transmission have been replaced and the rear end has been heavily modified. I expect these changes kept its value down. ... If you want a real Z28, you should keep looking for something more original and less modified.
Ya I was bidding on the car .. I agreed to pay 34k but was out bid at the last minute ... Now the owner is messaging me saying he will sell to me for 34500...
I like the mods .. Esp the 4 link rear end and the motor and tyranny .. I do t care it's not a fully done z28.... I do love the being a real black car tho and a real z ...
My big question is it worth 33-36k
Thanks
Mark
