mystery window felts
ok after going through everything I have I found a set of outer door window felts that don't fit my doors. I don't know what model camaro they go to. They are 37 inches long. I think they were ordered a long time ago by accident cause they are too short for my door. Anyone know what car these go too?
![Name: DSCF5314.jpg
Size: 117.8 KB](https://camaroforums.com/forum/attachments/67-69-general-43/29379d1501311959-mystery-window-felts-dscf5314.jpg)
If it is the bottom piece.
It looks like the inner door felt that goes on the door panel. The outer felt that goes on the door should have the clips molded in to them.
I can get you a couple of pics of my complete set and take some measurements for you if you want.
That would explain why they would be too short for the exterior. Would the interior strips also have holes for staples to attach to the panels like aftermarket second gen felts?
Ok that explains things. These would then be the inner ones. I will check when I get home but my door panels have them already. Also explains the other ones I have for the rear quarter that I thought were for the outside. So it means I am without outer front and back and good that the kit I ordered has both. Thanks guys
