Moving battery to trunk compartment
Old 09-15-2019 | 06:59 PM
Buchananr's Avatar
Default Moving battery to trunk compartment
General question on moving the battery to the trunk compartment. What's the trick - how do you get enough power to the starter to turn the engine over? Seems like all that cable creates a whole lot more resistance. Does the battery have to be upgraded, or heavier duty cables, or both? What are the pros and cons? Thanks
Old 09-15-2019 | 08:57 PM
I moved my battery to the trunk, there were no cons for me. The pro was having a less cluttered engine compartment. I also installed a remote starter solenoid on the inner fender to use as a junction point.
Battery Relocation Kit
Old 09-16-2019 | 07:15 AM
Buchananr's Avatar
I'm guessing the 1 gauge wire has a lot to do with it??
Old 09-16-2019 | 07:50 PM
Yep, the longer the run, the thicker the cable wants to be. Thinner wire/cable builds resistance, which lowers it's power carrying capacity.
Old 09-16-2019 | 07:54 PM
Everett#2390's Avatar
You should go for min 2/0 gauge (min 3/8 inch diameter conductor) and you can run cable over rear fender and through the channel under the door/carpet trim showing the Fisher emblem.
Tin both ends before adding terminals. The more strands the cable has, the better.
Old 09-19-2019 | 06:06 PM
Zspoiler's Avatar
I did that at one time using a Chrysler Direct Connection kit. And with the voltage drop it killed both batteries and starters. So I would use such a system on a Drag race car ,Not on the street.Its too much of a pain.
Old 09-23-2019 | 09:25 PM
Coach62's Avatar
I moved mine to the right side, just used the Summit kit. I grounded it to the body in the trunk and the engine would barely turn over. I added a jumper from the block to the fenderwell in the engine compartment, problem solved. I also upgraded to a top of the line AGM battery.
Old 10-03-2019 | 09:47 AM
Just1More's Avatar
by https://www.flickr.com/photos/153250783@N04/, on Flickr
Old 10-03-2019 | 09:49 AM
Just1More's Avatar
Old 10-03-2019 | 09:56 AM
Just1More's Avatar
Stormbringer1969
06-18-2018 08:15 PM
Milan
09-10-2015 07:55 PM
Texas70z28
02-03-2012 02:07 PM
jno
09-20-2010 04:38 PM
gozinya67
05-04-2005 02:23 PM
Quick Reply: Moving battery to trunk compartment
