Low voltage output - battery not charging
Old Nov 20, 2019 | 10:13 AM
Buchananr's Avatar
Default Low voltage output - battery not charging
69 Camaro, 350, TH350. Alternator only putting out 12.21 volts when running. At startup puts out around 14 but only for 4 or 5 seconds. If I don't have it on a trickle charger, half the time I have to jump it. Battery tested good. New voltage regulator. New alternator. Checked all connections and grounds with volt meter I know old time voltage regulators were adjustable but not newer ones. Good or bad idea to try to tweak the points on the voltage regulator? Any other suggestions. Appreciate any help.
Old Nov 20, 2019 | 06:56 PM
Everett#2390's Avatar
Ensure new regulator has the ground strap about one mounting rubber shock. VR chassis has to be grounded.
Use ohmmeter function of multimeter and check for less than 1 ohm between VR chassis and alternator case.
Swap in an electronic regulator and transfer the cover keeping original look.
Old Nov 21, 2019 | 08:17 AM
Buchananr's Avatar
Thanks very much. I'll look at those issues.. Any recommendations on an electronic regulator?
Old Nov 21, 2019 | 04:54 PM
Amazon or eBay, for about $12 - 20(?),, I think
usered
Feb 10, 2018 03:45 PM
pkasprzyk
Feb 19, 2013 09:32 PM
Jerry95lt1
May 3, 2011 05:59 PM
Masospaghetti
Sep 20, 2009 01:41 AM
sewerrat
Oct 13, 2008 04:10 AM
