Looking for header help
Old May 7, 2018 | 10:05 PM
Tireguy's Avatar
Default Looking for header help
I have a 69 base model. 350 block with angle plug heads, Power steering with 700r4 trans. The headers that use to fit the car well were full length . I went to the angle plug heads and now I have issues. Number 3 plug hit the header, I heated the tube up and tried to make a relief for it but I still burn wires. Other plug wires are starting to turn white from excessive heat as well. Anyone know of a good option for me
Old May 7, 2018 | 10:59 PM
Zspoiler's Avatar
Here are some suggestions for you.Have you tried a set Accell "shorty" spark plugs .I have a 1979 Z-28 RS Camaro Pro-Touring car with a 377 supercharged small block.That runs 15 Lbs of boost .With a set of Doug thorley "big Tube headers. So I know about heat. I use a set of MSD 8MM spark plug wires I use a section of a product called "Thermo-sleeve on my #5 cylinder because its very tight fit And for my starter wiring as well .I have had no issues since. Good luck to you.
Attached Thumbnails Looking for header help-130044932860518017_26257430996_o-1-.jpg
Old May 8, 2018 | 06:01 AM
flat tire's Avatar
I use 1 3/4" hooker super comps (2131 I believe) on my angle head SB 68 Camaro. I also use NGK plugs with a wire sleeve on #4 and 5 cylinder. burnt 1 wire to my carelessness in 6 years
Old May 8, 2018 | 09:25 PM
Tireguy's Avatar
Thank you for the advice. I has given up hope for my old headers. I've got a set of shorty plugs coming to see if that will be enough.
Old May 10, 2018 | 01:00 PM
Everett#2390's Avatar
Hooker 2130 may be a better choice, 1 5/8 inch diameter.
Old Jun 1, 2018 | 03:13 AM
Mmpusallc's Avatar
Default We used full length Headman built for high Raito pwr steering
they fit
no issues
We used a Dart DHP 550 HP 383 Stroker
LT1 T56 six speed
AFR NPT race ready angle plugs
thebandit110
Apr 7, 2012 07:48 PM
jwallace1025
Jul 30, 2011 10:14 AM
bashgod
Oct 31, 2010 02:10 PM
bkeaver
Jul 22, 2010 03:52 PM
1969camarofun
May 2, 2008 11:34 AM
