Led taillights
Got them from Easy Performance near Grand Rapids MI. They have the reverse lights in the center. They are programmable but I think I'll leave them alone an let them blink normally.
They are a simple install. Literally plug and play. Pull all of the lightbulb sockets out of the housing, unbolt the taillight assembly and separate the lens from the rear housing feed the wires through the rear bulb socket holes ,sandwich the circuit boards inbetween the housing and lens and bolt it back in. The wiring is in 1157 bases so they just twist into the old harness. You just use the outboard bulb socket for the entire light along with the backup light. They supply an additional wire that needs constant 12 volt in order to program sequential and other flashing sequences. I'm just letting it flash normally.
