67 cruise control
Old Jun 23, 2018 | 12:11 PM
ilikethebeach's Avatar
Default 67 cruise control
I have a 1967 RS/SS 350 automatic with factory cruise control. I've restored everything on the car and it's apparently rare. Question is my cruise control doesn't work as it's the only part I've not restored. Does anyone know how I can test it and where I can send it for a rebuild.
Old Jun 23, 2018 | 02:47 PM
peterpar's Avatar
You're right, speed control was not a common option in 1967. According to The Camaro White Book, only 305 cars were equipped with the option and it required an automatic transmission and a V8 engine. This is covered in 1967 Chassis Manual under Accessories. I've attached a pdf file I found that may help troubleshoot the problem.
File Type: pdf
Old Jun 23, 2018 | 05:52 PM
Default 67 Cruise control
Thanks for the reply, I'll perform the checks recommended. Any idea who might know anything about rebuilding the regulator?
Old Jun 23, 2018 | 09:30 PM
peterpar's Avatar
Sorry, no idea. I searched on teamcamaro.net for information and only found one discussion about air filters for the RPO K30 option.
Old Jun 24, 2018 | 06:51 AM
Everett#2390's Avatar
I suggest checking vacuum connections and servo itself.
Old Jun 28, 2018 | 10:20 AM
peterpar's Avatar
I found some information in the 67 Assembly Manual that may help with the speed control system. It shows the parts involved and where they're located.
File Type: pdf
camarokidrsss
Feb 6, 2016 05:30 PM
CoolRanch
Apr 24, 2013 12:24 PM
herr47
Jun 16, 2010 08:00 PM
voodoochile
Feb 9, 2007 04:58 PM
voodoochile
LS Series Tech
Feb 8, 2007 10:19 PM
