Just ordered a 572ci 670hp, any tips?
Yanking out the SBC. Is there a brand i should stick with or place where i can get the right motor mounts for a big block?
Im gonna see how my radiator does, it might be big enough already.
Anyother issues i might encounter putting this in? Its a Dart Big M block, Dart platinum pro heads etc
Most any aftermarket place has BBC frame mounts - moves BBC 3/4 inch over to pass side for better fit of drvr side exhaust - unless you have rack & pinion steering, then not a problem using SBC frame mounts.
As flat Tire suggests, I will add solid subframe mounts, Moroso has them.
The big block mount arrangement also moved the engine forward a little bit to give more firewall clearance.
Camaro Small Block to Big Swap
