Jacking Locations
Old Mar 20, 2010 | 08:21 PM
1969_RS's Avatar
Default Jacking Locations
Just wondering where is the best or safest location to jack up my '69 and place jack stands. I know corvettes are very particular when it comes to proper jacking locations, don't know about the 1st Gen Camaro.
Thanks in advance!
Old Mar 21, 2010 | 11:22 AM
If you want the suspension unloaded, then the safest place is under the subframes. In front it's anywhere along the flat portion, and in the rear it's just in front of the front spring perch. If you're not wanting to let the rear axle hang free, then it's better to use the axle on the jack stands out back.
Old Mar 21, 2010 | 12:12 PM
In the back, jack up from the center section and place the stands under the axle tubes at each end. In front, you can jack up under the crossmember, and put the stands under the lower control arms. If you're worried about dinging the crossmember, put a block of wood between it and the jack.
Old Mar 23, 2010 | 07:19 PM
joshtimber81's Avatar
Nice look! If you are interested then I am giving one advice. Make the car body in black color..
sabukudragon
Jul 19, 2011 11:39 PM
dm575
Dec 5, 2010 10:20 AM
wils5150
Jun 29, 2010 07:29 PM
1995CamaroZ28
Jan 6, 2009 02:56 PM
dd11
Mar 18, 2007 08:15 PM
