How to tell if its what they say it is?
Old Sep 5, 2007 | 12:29 PM
Bull's Avatar
Default How to tell if its what they say it is?
I have been looking around at camaro's for the last yr or so...and I have found a few that arent in bad shape, but would like to know for sure(if possible) if the car is a real RS or just one that ppl slap parts on to clone?
any help is greatly apprishiated
Old Sep 5, 2007 | 04:27 PM
damnameisinuse's Avatar
Default RE: How to tell if its what they say it is?
The easiest way to spot a fake is the tail lights. The RS has separate backup lights on the rear valance below the bumper, the standard ones have backup lights in the center of the tail light. If they just wanted hideaway headlamps, thats easy to spot. If they did the valance too its a little tougher and you'll probably need the options from the trim tag, you can come here and decode them to find out if its a true RS or not...
Old Sep 5, 2007 | 06:38 PM
Bull's Avatar
ok well heres the tag info
BODY BY FISHER
0211200[/align]ST68-12437LOS2898 BODY[/align]TR712 R-R PAINT[/align]
Old Sep 6, 2007 | 04:40 PM
ORIGINAL: Bull
BODY BY FISHER
Maybe the trim tag doesn't tell as much as I thought...or maybe I'm not reading it right. Hopefully someone else can chime in with more help, but from what I gathered at this site: http://www.holisticpage.com/camaro/parts/68trim.htm#f Its an 8 cylinder coupe, interior is black with standard bucket seats, color is matador red. I really thought there was something on there that said for sure whether its a Rallysport or not too...but it looks like I was wrong.
Old Sep 6, 2007 | 07:12 PM
MichiganMan's Avatar
January 2008 ROTM
on a 67 tag there is a code for rs not 68 or 69 bull check your private message you have one
Old Sep 7, 2007 | 09:29 AM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
https://camaroforums.com/m_79309/tm.htm
Old Sep 9, 2007 | 04:32 PM
January 2008 ROTM
its a los built car good chance there is a buildsheet under the gas tank. could answer all questions if its still in good shape
Old Sep 9, 2007 | 09:03 PM
buckmaster's Avatar
RS will have unique headlight switch for one; look for 2 air inlets on the side of the headlight switch. Also, the vac hoses will be running from the headlight switch thruogh the firewall. Even though most of the vac systems for the headlight covers have been abandoned, the original lines and switches should still be there. I have been cleaning up my rs and have purposely left all these original parts in their "as found" condition, right down to the dust. My car also has a somewhat rare option for headlight washers. The washer pump has an additional liquid port for headlight washers. I believe this was an RS option only.
