How to determine the cause of Passenger side being 1" higher than drivers
Not too bad, read here, but they left out one problem, antiseize for the hardware going back together as it will make it easier later in life.
Also, in preventing stripping and breaking, unscrew to the point of stopping, spray threads with lube, i.e., WD40 or equivalent, then screw in, then screw out, repeat until bolt is out.
Sub frame bushing replacement - Team Camaro Tech
