Help on where to find underbody cleanup posts
Old Jan 7, 2019 | 01:23 PM
wendon65's Avatar
Default Help on where to find underbody cleanup posts
Good day everyone,
So my project has stalled for 3 years now. 1968 Camaro restoration. I got it back from the painter 3 years ago. I stripped it down to a rolling Chassis.
New years resolution is to get going again. I stripped off all front end components and dropped the sub frame off to be sand blasted and powder coated. For the next 2 weeks, my goal is to cleanup firewall and repaint. (Almost done stripping it down) As i get low, I am thinking that I should clean up the underside of the uni-body. Here lies my issue. I want to make it look nice and also understand its going to be a workout. I have stripped off rubber before with a small torch on low and hit it with a putty knife. Question....... How clean will I have to get the metal and what do I put down after it is stripped down. I am not a painter so I don't really know. Obviously I am looking to do a nice job and still progress along.
Thanks to anyone willing to chime in.
Don
Old Jan 7, 2019 | 03:57 PM
flat tire's Avatar
you can sand blast or use a cup brush on a grinder.
it has to be CLEAN IF YOU WANT PAINT TO STICK
mine had no undercoating, so I laid on my back with a pressure washer. then I think I used maybe 8 cans of rustolum
Old Jan 7, 2019 | 08:47 PM
wendon65's Avatar
Thats what I was assuming. It’s definitely not an easy job. I’ll scrape and then wire wheel it with the grinder. I was hoping there was a good coating that would go over a scraped undercoating.
Old Jan 8, 2019 | 08:27 AM
Zspoiler's Avatar
Just clean it up real well then get a number of cans of undercoating,
old timer
Jul 3, 2011 07:06 AM
Jr. Mechanic
Mar 16, 2010 01:32 PM
TJ_HOOKER
Jun 8, 2009 08:03 AM
CCarRocks
Nov 2, 2006 12:01 AM
brandon_66679
Aug 26, 2006 12:50 AM
